DOUGHBOYDD2500HD
- Aug 3, 2005
- RTP
What is the best tire to use for a all around multi purpose use?? Ride quality/long lasting/and durability/low to no road noise. Thanks.
Bfg all terrain. No question.
You dont really mention off road ability or performance.
If thats a low priority check out a set of Michelin LTX A/T. They are a Sams and Michelin direct tire only. They are not AS aggressive as a BFG ATs, but are better than the long trails or similar more road aimed tires.
They are also Load Range E, and between me and my old man we have ran 3 sets of them. All 3 got at least 80k, and he actually ran one set 115k....they were pretty much used up, but not slick by any means. And they did OK off road on hunting trails farm use etc. I never wemt and played in them and wouldnt recommend it, that isnt their place.
The Silent Armors are backed by a really good warrentee. Can't remember specifics but it was impressive when I looked into them. Goodyear is backing them heavily. Probably what I'll run when my tow rig comes to the front.
You know a lot of you people keep talkin about your rears wear out faster then the front.... Are you not rotating them? (SRW)Goodyear Wrangler Silent Armors have faired me well so far! Got one replaced free under warranty 'cause it got a stress bulge, no other probs though! Just hafta rotate 'em, mine's an extended cab shortbed Dmax, the rear tires wear out a lot faster than the front!
I rotate them F to R but not much maybe at 20K or so if that and they went to 60k. The front and rear are about the same other then a little rounding on the edges of the tread from turning. I think the people that have the tires wear fast on the rear don't have a load on the rear so the rear scrub and spin a lot. If it has a load it plants the tire and will wear better.
My truck has a camper cover and gear in the back all the time, when it was new I would spin the tires all the time, now loaded it does not if you don't try.
BFG Commercial TAs for tow rig. Can also get M+S tread.
