These games will fit you perfectly.
Roll to the line
You and a judge take off from point A. you will have about 20 ft. from starting line to use throttle. Then after that you(driver) have to release all pedals. No gas...no Brakes..you will then coast,swerve..whatever it takes to get your right front wheel closest to a line without crossing it. It all depends on initial throttle input, and how well you can scrub off speed without using brakes. In the past I have won this event by getting 2 inches from the line. Some winners have been 1 inch or less. The last time I did it..i think i ended up 15 ft from the line.
Nudge the jug
water filled milk jug with a tennis ball perched on top. You and your co-pilot take off from point A. Driver is to first nudge the jug with passenger tire, to get the ball to fall of without crushing or knocking jug over(Driver/co driver communication is a must)..then race towards a turning pole, turn around and then nudge the jug with drivers tire. All it takes is a slight nudge, and the ball will drop. Then race to the finish line. All timed, so go fast.
Spear the ring
Long flexible fiberglass pole, ring clipped to a tree limb. Driver drives, passenger totes the pole. Passenger must spear the ring and unclip it, then race towards finish line.
Passengers hands cant go past a line on the pole..Very fun, and not as easy as it sounds..trust me. Driver/co-driver communication is a must! Timed event
Balance beam
2 huge solid oak beams perched on a steel ''I''beam. When the judge says go..roll up on the beam...fastest to balance wins. I have seen the winner turn in a time of 1.9 sec. but thats not normal. Very fun..timed event
Ball and post
2 2x2 post driven into the ground, the top is cupped so a rubber kick ball will balance on it. Driver takes off, driver pulls up to the 1st post, grabs the ball, hands it over to the passenger, passenger places ball on the next pole. Be careful driver...make sure the passenger has that ball balanced on the pole before you speed off. Then it's to a turn around pole and guess what...you do it all again, on the way back in reverse. passenger grabs the ball off, hands it over to the driver and he places it back on the next pole. Vehicle is in reverse gear also!!! Very fun, timed event.
These games are meant to be a fun way to get together,compete, and have some fun. This is not a rock crawl comp, or even a race, but I have found that these games still bring out the competitor in most!!! Very fun and for a great cause.
There will be trophys awarded for the winner of each event. We will also award 1st 2nd and 3rd place overall trophys. You dont have to win a single event, to do good ''overall. Just be consistant in all events.
