stevewes2004
- Nov 7, 2007
- Concord, NC
I wanted better spool than the II Silver 62 I had, with good top end, and the ability to support around 600hp. So really my only option was TWINS. Its not complete, but making good progress. I should be done within a week or two. Here are the pix i have so far.
Gutted
Some parts
two 55psi pop-offs with weld-on bungs
soldnoid plug for the HE351
manifold is painted with VHT paint
manifold flipped
got my big turbo oil feed and drain on
oil drain for the 3B
got this housing for the HE with a spring wastegate, the cold pipe, hot pipe, and the 3B from a guy on another forum. saved me a lot of work!! which is good since i have a little one at home with limited time off.
ordered a 5" exhaust to match the 5" downpipe required for the 3B
turbos unfinished with the exhaust housings removed
mounted up the exhaust housings/hot pipe to fab the down pipe
more to come..........
Gutted
Some parts
manifold flipped
