Cperry
- Apr 24, 2005
- Durham, NC
So the crankshaft in my chevy broke in half not good........
Bought a semi complete 95 Dodge 4 wheel drive. my plan.
Motor is complete with 5 speed bell housing attached no tranny or t-case. I just rebuilt the tranny in my chevy so I am going to use that. After i pull the motor from the dodge i want to re gasket the whole thing on an engine stand. I don't really need or want it to be the fastest thing on 4 wheels but would like to do do the important hard stuff first.
Q's
- Should i replace the head gasket while its out, what gasket should i use and should i go ahead and do ARP studs. What will a stock or affordable head gasket hold boost wise with Studs?
- Will I need to change my chevy input shaft on the NV4500 to a dodge input shaft.
- what clutchs are acceptable
- Why are the KPD pin kit $80 for a gasket bolt and a tab
-i have pyro guage, and boost guage, do i need a fuel presure guage
- Is stock fuel presure accpetable or do i need to upgrade
- Injectors these have 260k on them is it time to replace, if replacement needed what should i go w/?
- I have 4inch exhuast on the truck already is stock down pipe acceptable
- going to do a fuel plate mod and govener springs and tweek turbo
- what else do i need to do should do form the start
Q's
