cut and stretch CJ-7
Breaking News...
From either LeeBoy direct or a parts vendor (I spoke with Diane from Arrow Equip. in GSO) for LeeBoy "635B" Grader:
Housing, Ball Swivel #640051 $55.00 (front weld on socket)
Ball, Drw-Bar Swivel #640040 $52.50 (ball itself)
Shim #640150 $4.75
Housing, Ball Swivel #640031 $48.07 (rear of socket w/ hole for stud)
$160.32 + tax/tags/title/S&H from Arrow Equip... (not in stock, but usually overnight
Shim #640150 $4.75
great job on the search, my buddy hasn't got back with me on that yet.
I will see if I can find some picks of the rear flexing. I have a video if I can figure out how to post it. it's when I backed up the rock and broke my front shaft. I know I have some pics with it up using the lift truck.
right now I can get a yard stick under the front tire before the back tire lifts. It would go a lot futher but I have it limited due to shock and spring lenghts. I could easily get 48" + if it was not for these factors.
well I think I got a little video to work check this link, its pretty funny.
http://media.putfile.com/break-60
Hey madssjeep, can I get more info on that fuel tank and mounting?
hey bubby, Its a stock CJ 15 gallon tank, I wanted a YJ tank but it did not fit my application( too wide). basicly before I built the tub I finished the suspension, flexed it with the tank in several locations and once I found one that worked, I fabbed some brackets and welded it in. The fill is located on the side beside the opening The hard part was clearance. I had to design my floor up about 2" above factory location so it would clear. You can't tell by the pics but only a person about 5'6" or so will fit in the back. My head is equal with the cage and I am 6'1".
mbalbritton said:
I think I'm gonna be sick... next time give the camera man a tripod....:D
you ain't kiddin. I thought Scott was drinking, but he was running up the rock to get to the top. that sick feeling was being felt by me too.:D
