- Apr 16, 2005
- Sharon, SC
I was about to say...technically...Yea they were finished... by Woodlee.
If there is one doc in the world rich enough, passionate enough about off roading, and dare I say it - crazy enough to pay David to build an offroad car for him...it can only be Nazir, right?
I have eternal respect and gratitude for him. I hope it's not. For his sake. But I mean it sort of has to be, right?
You might move the tube that's behind the driver's helmet first. Then make room back there for the rear shocks and a radiator.I've been thinking about raising the roof some more.
The last pair seemed like a deal a lot of people weren't ok with?It's ok if they go other places to get finished.
So how'd this thing do last weekend at the Hammers?
There is a huge gap between what I believe and what the public believes.
Bomber fab
This thread has no room for logic. Get out!Have you looked at how Randy Slawson designs a chassis? There might be some pointers there. I think he puts tubes well away from the driver's head.
Is this really for Adam Carter?
Too tall!Is this really for Adam Carter?
Not for Carter... building his own.Is this really for Adam Carter?
Dang man, I have a pair of those Ironman underwear too!I was able to tinker with this trailing arm a little bit this week, but Saturday is usually my most productive day drawing. Alright, so what I've done here is I've gotten rid of the heavy wall tube design trailing arm, and the heavy billet idea. I can build this trailing arm setup solely relying on the Motobilt laser and press brake.
That trailing arm looks cool and all, but it seems massively over-complicated, which means it's probably much heavier than a simpler design. The thing that strikes me about this: You don't want to make it from tubing, so you designed it with....fabricated tubing.
Is there anything preventing you from making it narrower and deeper, instead of wide and flat? Wide and flat is not especially efficient when you're making something loaded primarily in bending. Wide and flat can work, but it has to be far heavier than needed to compensate in bending. Think about why a tall-narrow beam section is stronger in bending than a shallow-wide beam section.
It's only job is to be strong and stiff in bending, so that's where the design needs to be. The tension/compression and minor torsion is pretty trivial when it's got enough bending strength.
Deeper toward the roofline (top side), not toward the ground plane. There shouldn't be boulders on the top of the trailing arm.I think if it was narrower and deeper, it would drag more boudlers. The design theory would concern keeping the lower shock eye below the center line of the trailing arm like it is. Over complicated is subjective. From a shock tuning aspect, I can pull these shocks quicker with the overhauled design.
