In the works.Looks great!!!! Remember rear tracion bar! (very____ strong rear traction bar)
I decided to do a three link, not a radius arm setup like you posted. Typically a three link will flex without binding better than a radius arm setup. The radius arm is probably a little simpler to set upOk,
could u have welded the upper to the lower link once ur angles are correct? Here is an example.
http://inlinethumb46.webshots.com/42...600x600Q85.jpg
Is there any disadvantage or advantage to doing this versus each link having their own separate mounting location?
Got the sliders finished, rear bumper made, ram, res, orbital and cooler mounted, limiting straps installed. Trying to get it ready for Mt. City this weekend.
Going to run the bed for now. This is stage one. Stage two will be after I end up bashing the bed, then I will 4 link the rear and loose the bed.
