Ok so question... since I am a Diesel Newb...
Yes I am looking for a good diesel that I can convert to WVO.. but my question is... with a diesel can you install an automatic started so you can start truck from inside house in the morning so by the time you get out there it is warm enough to switch to grease??
I know some have to let the glow plugs start before you crank it... so I guess if the remote starter had a delay on it then it should work correct???
also I have heard that with some remote starters if your car or truck is running you can reset remote start while vehicle is running and then take your key out of ignition lock vehicle and go inside store so you do nto have to worry about turn truck/car off and also if someone breaks into vehicle as soon as the push break pedal it will turn off without key in ignition..
so wouldn't this help also with quick stops to run into stores etc.. since that way you do nto have to switch between diesel and grease at each stop...
mainly just thinking out loud...
