ECORS - Possible In car camera or Wheeling Camera
burrellsjeep
Breaking Stuff...
Morganton NC
The guy I work with is a gun guy and showed me this, I thought it might work great for a in car camera, The site says it records 200 mins at 30 fps (real time) with sound, all to a SD Card. Runs off AA Batterys and it is water proof up to 20 feet. Weighs hardly anything it is used to take on a hunt to record it. Just thought I would share.
Stealth Cam EPIC Digital Video Camera 5.0 Megapixel Black $75 - on sale
If you read the reviews on that cam, they are mediocre at best, when compared to teh quality you can get form otehr cams these days.
Last fall, right before the Fall Brawl, I researched this a lot just for this purpose.
I bought one of these -
http://www.tachyoninc.com/
Tachyon XC. Thus far I'm pretty impressed by it, I've used it as an in-cab cam for both races and it held up very well. The image is very stable. The cam is submersable down to 2 atmospheres, that's when teh electronics start having presure problems.
it has no moving parts and a very minimal LCD screen so there's nothing to "break", all solid state. Streams right to an SD card, I got a 16 Gig card and that gets many hours of video.
During teh last race, the screw holding it to the mount unthreaded and it fell down iunder my back seat, whereit was knocked around for the next hour. No problems at all from that.
My only complaint is that ths sound quality is terrible - this is b/c in order for it to be so water-tight, the mic is inside the rear trap-door where you access the batteries/SD card etc, so it is covered up. Supposedly you can get better sound by leavin that door open, but I wouldn't.
That looks good. How is it mounted? I have seen some of the GoPro video's too. They look good. These were posted on NAXJA:
it uses the tripod mount and has Velcro that raps around the exo cage so I can move it around to different view points..
I'm still fighting battery issues with my GoPro. It's supposed to save before the battery dies...mine does not. I got nothing out of the ECORS race or the last RCrocs race I did. Short runs like xrra do fine because I can turn it off and on. Looks and sounds pretty good too.
I got some different rechargeable batteries now so we'll see in a couple weeks...
I'd like a video camera that can have A/V input from the intercom system so on the video you can hear the driver/co-driver chatter and chatter back to the pits as well as typical other sounds (horns, rocks, other vehicles, etc.) without too much interference fromo wind or overpowering engine noise :)
What I've learned is, you have 2 paths to choose between.
1 - a cool camera with a lot of functionality, some iputs, maybe a good screen, HD video, etc... or
2 - one that is specifically designed to be dropped, beat, submerged, slammed, dusty, etc.
In order to meet the requirements of #2, you have to elimiate all the neat stuff from #1.
The 1st and 2nd 4x4cross races, I used a Flip Video camera. First time, it was the $30XJ.. .to make sure it was solidly mounted, we literally cut a matching rectangular hole in the dash and sank it in there, and ran a bolt up from underneath.
Here's a link:
The 2nd time I mounted it via 2 bars hanging down over my shoulder in my 4Runner. That video came out completely unusable b/c the vibrations were too bad, it shook all over the place.
The Flip is a neat cheap camera, the problem is I'd bet if it got a good hard knock from osmething (liek a helmet) it'd be toast.
The key clearly is the mounting and being sure there is no way it can shake. My Tachyon is mounted via a 3/8" flat bar hanging down w/ a sort of shelf on it - it cannot vibrate at all.
I need to edit/trim down my vid from las tweekend - but at one point my copilot's head hit it; it cocked sideways so the next 10 mins is staring at my head, lol. Then teh bolt unthreaded and from then on, it's all video of under the seat.
re: Will's battery problem, I read carefully about that - the cams with screens etc do not have long battery life, at most a couple hours. That's why I chose this one, 2800mAh batteries, it's good for like 6-8+, more than a 16G card will hold.
The Tachyon also streams to the card constantly, and ends the file every time it hits 1G - so you can't lose the video from battery death, or at the most the last 10 mins or whatever. The only downside to this is that there is a short (few secs) break between thr files, but that also means teh raw video is a manageable size. Ever tried to load/ play a 4 gig AVI?
the hd GOPRO is definitely the way to go, they give the best videos for the 300$, waterproof up to 180ft, 30-60fps, or 5mp photos. I know few people that use them for skiing and they are awesome, (vid off the site)
http://www.goprocamera.com/hdheropreview/
and im pretty sure you can set the recording time so you can have it automatically stop at say 2hrs
anyway to hook up the gopro to the intercom system?
Rob, even if it had inputs - how would you get the sound into the car to begin with? An extra radio?
From inside the vehicle you can't really hear much from the PA, aside from when you are stopped/slowed down... just a lot of engine revs, things banging/clanking around and a lot of suspension crunches :lol:
I think you guys are misunderstanding my question...
intercom=in-car intercom system so driver and co-driver can talk to each other (vox mics and headsets)
Woops, you're right, did misunderstand.
Personally, I rather not have THAT on tape anywhere, lol.
This past round, it was mostly:
"Woah slow down! Go left. Now take it easy as you go down here. Easy, Easy! Save the tires! Easy! Slow down!
OK hit the tree this time!
Oh no no I was kidding!..."
ROCK ON!!!!....right??lol
