Hey,
I just got a '92 W250
Well I finally got it on the road and have notced a few things...
1st: from 0 - 55 no problems with engine , etc... but when I get above that speed every once in a while it will buck and I have to let off the gas and then press gas down again and it will keep going... if i say in gas it just keeps slowing down.
I did change the fuel filter when I was changing all other fluids..but I am not sure how to check to see if there is air in the lines.. and if there was air in lines how do i get rid of it?? and would air cause a problem liek this??
or could it be something with fuel pump??
2nd: the heater/fan controls in the dash do not work..
has anyone actually pulled there dash apart??
and if so where these cable driven?? if cable driven can you get to them easy to fix or is gonna be a real pain in my arse??
3rd: Having trouble with tranny sticking in 5th gear.
1st threw 4th I can shift up or down with no problems at all and very very smooth.. but not every time does it stick just once in a while.. I will be driving along and then want to down shift and it sticks in 5th. so i have to push it back into 5th and then I double clutch it and usually i can get it into 4th..
Thanks for any advice in advance..
