Fabrik8
Overcomplicator
- May 27, 2015
- Huntersville
Let me just say that I am so damn glad I switched from Aerospace to Computer Science!
Scared of spec'ing wood beams for airplanes?
Oh, and it'd be very interesting to know if there is a thickened footing under your pole. That pole is necessary but probably doesn't offer enough bearing surface to keep the LVL's from crushing and the diameter is pretty small. We usually see a steel column with a larger cap and base used for this or a parallam (laminated) post with cap and base.
You could likely put a flinch plate on both sides of the beam and you'd probably be good without any support except at the ends.
That depends on whether the PO was a good boy and pulled a permit when he built itOne more quick question though, would the permit office have a copy of my building plan? The garage was built in 2006
Oh heres another thought... Mount an I Beam under the beam and support it at the ends... No joist removal required for that..
Someone else had mentioned that previously, I asked what size Beam would be large enough. 6 or 8"
Neither.
Are there load bearing walls upstairs? You're looking at a W12 or bigger either way.
Were fat girls and jump ropes involved....<-- has personally attended a house party where the floor collapsed.
check that I dont want the answer.
Why are you limited to a 12" beam? I just put 2x 24" LVLs up a span of 22' without issue. Likely overkill, but stories of fat chicks and jump ropes make me worry...
