FS... Doubler for an XJ
snappy
YHDG's adopted son!!!
Moderator
high point
Up for grabs. 1 doubler for an Xj. Increases strength of the stock dana 30/35 combo to that of way more than a built dana 60. Cut the heck out of your fenders, add 39 or 40 inch tires an be the most badass cherocar on the frontage road!!!
Price....$3500 this is a steal....
Offers intrained....
:popcorn: oh this should be good
Is it for a car or a boat?
Can I install this behind my current doubler? Would that make it a quadrupler??
Oh and how much body lift would I need to clear 42's
Yes you can but then you could run 54" boggers with a 2" lift and 6 packs of sawz all blades....
i have 2 1/2 ton military axles with dana 60's in the rear and dana 44's in the front .................. do you think it will work with that set up. oh yeah it's in a subaru, will that be ok?
Thats 4 axles you will 2 doubler set ups, sorry
If running this on a Landcruiser split case will I need to upgrade to the Lexan input shaft with the chromoly extended filler tube or will the shear spring on the indicator bulb not be able to resonate the appropriate torque power through the standard banjo bolt?
Not sure on the lexan, but it will work with the pirex i know for sure. As far as the other goes, the best way would be through a modulator reed valve...
put me down for one if you can part with a free bottle of blinker fluid............
i know you said this is for a xj but could it be adapted to fit a toyota?
i've got a welder and can fab pretty good. i'm sure i'll have to make the front
driveshaft longer and the rear shorter but i got some conduit that would work.
also if i weld up my front diff will it make it harder to steer? i've looked in the
diff cover and i can't find the c clips to do this mod.but i think if i put some
springs in that empty space between the spiders it'll make it into a limited
slip right? how much for the doubler shipped to tanzania?
You have any exhaust fluid with the muffler bearings, shit, they made that a real thing now. Ruined that joke.
Sent from my DROID RAZR using Tapatalk 4
