paradisePWoffrd
Recovering Project Junkie
- Nov 5, 2005
- Newton, NC
You could also look at the bearing sizes. IIRC, a 1 3/8" inner bearing and 1 1/16" outer bearing = 3500 lb axle.
X2. bearing size will tell more than axle tube size.
you mean the size inside to inside of bearing hole or the full size of the bearing outer diameter. good info to know though..i will check tomorrow when i finish the last step to replace 4more u-bolts.You could also look at the bearing sizes. IIRC, a 1 3/8" inner bearing and 1 1/16" outer bearing = 3500 lb axle.
they are new already and packed ready to go.I say open up a hub. It probably needs repacked/bearings any way.
I think you will ultimately regret not putting all the board in for a couple reasons.
Just one man's opinion.
...didn't realize the weight similarities. i only left the center open mainly for money purposes but figured the 300lb loss was added bonus. money is tight right now and when i get some back up, trailer brakes are my next buy. the center being open is the least of my concern and as far as strength and rigidness...with all the extra angle iron i put on, according to metal shop too, the floor is now stronger than i would ever need it to be for any purpose i ever will put on it. they told me that floor should withstand 8k pounds no problem (just floor itself). for a jeep probably overkill but figured better overkill than not, without being so heavy. once i get at least one axle break installed ($60), it will be a great lightweight hauler. today i bought a 29spline 8.25 off a 00xj which could've been one set of axle brakes but couldn't pass the deal on that diff (my turdyfive took/handled some beating but still taking a chance with it lol).3/4" PT plywood is about 90 pounds per sheet whereas a PT 2x10x16 is about 70 lbs. You aren't saving weight, you're losing strength and rigidity. You'll wish you had the center in there when you need somewhere to work on it.
Listen to others in this thread who have some experience and wish to share it with you.
i figured since the law is just one but eventually why not both for extra 60 down the road!! i'm just so relieved to not have to borrow that 2300lb tank (lol) of a trailer for my trips... the ford done it but it wasn't happy coming up the mountain lol pullin 43mph steady though, but flat ground was doing 70 no problem so with my trailer weighing 1/4 of that, i'm sure the ford will have much more breathing room along with smaller tires, upgrade the exhaust and intake, maybe a chip and i should be plenty. Surprised it done half tank a gas from Boone to Marion and back with that heavy load!!Two braking axles is nice but most trailers only have one braking axle. My trailer is similar in weight to your carrying an xj and one set of brakes is plenty
X2. Don't be afraid to let that 5.4 live near the redline on hills.Are you sure the truck wasn't happy. We have a f350 with a 5.4L and it will pull just abut anything. I've towed my old fullsize bronco many times on a equipment trailer.
You have to keep in mind old v8s like the 460 and 454 made gobs of torque low in the rpms. And now modern v8s get compared to desiel engines.
The 5.4 makes power pretty high in the rpms.
That truck has plenty of motor to pull an xj.
hey thanks for the input on the 5.4 I took it easy and kept rpms low not wanting to cause any damage/stress...i'm not a ford guy and don't know much about them but glad to know it can handle some rpms. thank you.X2. Don't be afraid to let that 5.4 live near the redline on hills.
thank you also for your feedback on the ford..glad to know i can get on it when needed. it did pull surprisingly well with really good gas mileage for the amount of weight it was pulling but up the mountain i kept slow just cause new vehicle for me and until i get to know it, i take it easy. thanks for input!Are you sure the truck wasn't happy. We have a f350 with a 5.4L and it will pull just abut anything. I've towed my old fullsize bronco many times on a equipment trailer.
