burrellsjeep
Breaking Stuff...
- Nov 19, 2008
- Morganton NC
The build is what’s left of a CJ-8 Scrambler that good friend of mine is in the process of finishing up. In exchange for machining work he is doing for my jeep, I agreed to document his build for him since Justin is not the internet savory type and I thought this had be posted.
I will be just documenting this and will take no credit in the build that’s all Justin.
I will have him sign up and comment on the build, I will just be doing the posting and updates.
Specs:
Picture of what it looked like four years ago, Trail 3 in Tellico
The Jeep is currently mostly though with the first mock up build. It is almost to the point at which its close to being torn down for finale assembly. I will be getting more detailed pictures as the build progresses. He has some photos and I will post them so you can get an idea what its going to look like.
Specs:
- CJ-8 Scrambler Frame and Body with an O5 Liberty Hood and Grill narrowed 8’’
- Custom Internal / Exo Cage with an integrated console with Cage mounted Corbeau Bucket Seats
- Rock Sliders with integrated storage compartments
- Mercedes 300SD Intercooled 3.0 Turbo Diesel running on Diesel and Veg oil.
- Flexalite Radiator, RCI Fuel Cell, Custom Stainless Exhaust
- Custom Built Bellhousing and Custom 9’’ Torque Convertor
- Ford C4 Manual Reverse Valvebody Trans with a AA Tailshaft
- T-Case adaptor with Spud Shaft to adapt to a Ford NP205
- Custom Monotube adaptors
- Mercedes Unimog 404 factory Monotubes and Axles
- Factory Unimog Wheels cut and reversed
- Michelin XML 385 95R20 DOT Milspec tires
- Custom Cantilever Suspension 2:1 Ratio with 4130 Chromo Arms, Tapered Roller Bearings, and 4340 Shafts.
- Prototype Closed Loop Pneumatic Air Springs 12’’ Stroke 3’’ Bore Mounted Horizontal.
