CasterTroy
Faster'N You
- Mar 21, 2005
- Wallburg
I've got a set of corner guards now I need to install, and I want to install them UNDER my Exogate tire mount. The exogate comes with a 1" spacer for the hinge side on the body to extend it the same amount as the frame on the tailgate.
So to delete the exogate spacer and still be the same thickness as the tailgate, I need a 7/8" (technically a 13/16") poly or aluminum or steel spacer to go under the hinge now after mounting the corners.
Any advice on what to use? Where to get it?
(How do you like the way I pulled that dent out @Jason W. @Don M @Joe J. ? )
Seems like it would be easy enough to knock out on a mill if one had the dims needed. I might have a piece of aluminum or delrin/hdpe big enough to get it.
