Jeep SRT revival
Bellhousing bolts and it's ready to pull
If the block is salvageable, I'm gonna rebuild it myself and add MDS delete with a better cam.
If the block is trashed, gonna pull the trigger on a crate Mopar Performance long block
Does the Mopar Performance long block delete MDS and have a better cam? Or just a similar replacement?
You can buy a later model long block that has no MDS. There's a MP dealer that can add the cam while still maintaining the warranty. That's my worse case scenario.
Just need a canned tune to turn off the CEL that way
Mopar Perfomance.
le performance de mopar en francais :D
Found one in VA that sells the long blocks at a very reasonable price. Enough savings to justify a road trip for a day
Gotchu.
I know that Arrington Performance was great to deal with. When I was working on that engine, they sent me a used rod/piston from a donor they were building.
During the discussion, they mentioned potentially buying one of the blocks with scored walls I had available, since they would bore it anyway. Ended up giving it back to the customer but it might be a cost saving option for you if you're road tripping to VA already.
If you’re already doing a cam and tune, have you thought about slapping on a OE supercharger?
Not going full gonzo on upgrades. I'm not keeping this one long term or anything.
Gonna fix it correctly and reliability is key.
If I were keeping it, I still have my old Fox Body license plate.
I GO TENS 😉
Contrary to most men's belief...
8 is better than 10. At least in this case :D
