XJsavage
CounterCulture
- Aug 15, 2009
- Lyle's Ford SC
That is badass!!
.Yes, I designed it in Creo, and had my buddy in the shop laser cut it and bend it for me.Nice man did you laser cut the trans bracket? Looks beefy!!
I'm undecided. Do you think it is necessary? I know it is common to break the tail housing of some transmissions like a TH350, but I haven't heard of it happening on an AX15. I'm going to be building another crossmember just like the one in the pictures above right there under the rear output yoke for the traction bar to connect to, so I should probably just hook onto it with a rear mount for the Atlas.Good to see you back on this thing. And as always, thanks for the ideas to steal.
Are you going to support the back of the Atlas or just let it hang off the back of the trans?
Thanks. I am not a fan of the way a lot of people do it when they hard mount the bracket/crossmember to the transmission, then attach it to both frame rails with bushings. The bushing is needed right under the transmission for the drivetrain to float when the chassis flexes. I welded steel sleeves through the frame rail so the bolts are not just pinching the two walls of the frame. I didn't take a picture of that.Never thought of doing the crossmember like that. Good idea
I have seen a few people break tail housings on multiple transmissions because they did 2 mounts. (1 on trans, 1 on t case)I'm undecided. Do you think it is necessary? I know it is common to break the tail housing of some transmissions like a TH350, but I haven't heard of it happening on an AX15. I'm going to be building another crossmember just like the one in the pictures above right there under the rear output yoke for the traction bar to connect to, so I should probably just hook onto it with a rear mount for the Atlas.
I am taking notes on both builds! Ya'll hurry so I can nit pick and wrangle some juice from each. As for the link comment. Its a sane choice. I however feel the platform is better served as you fellas are approaching it. If its links coil overs and the whole mess just build a buggy. I view this approach as very grass roots and more like resto mods. The fun is improving. If I want a race car I'm gonna build a race car. A Jeep remains a Jeep when certain characteristics of its soul remain. A grill, tube, and coils is not a Jeep.I don't think it can hurt. In our cases it serves a few purposes if we hang the traction bar from it. I have the TMR support ring for the back of the Atlas and was planning on using an OEM style poly mount for the 4L60E at the transmission if at all possible. If not, Advance Adapters sells one that is cut to bolt to the adapters. Also, I agree we are foolish for trying to keep it low on leaf springs. However, linking stuff on OEM frame vehicles without a lot of cutting requires a slew of compromises as well. I do dig the shit out of the way you've designed and cut a bunch of the stuff for yours vs the just off the shelf stuff I've done on mine.
My buggy has the mount at the trans like yours, no rear support or anything under the atlas and I beat the crap out of it without issues.I'm undecided. Do you think it is necessary? I know it is common to break the tail housing of some transmissions like a TH350, but I haven't heard of it happening on an AX15. I'm going to be building another crossmember just like the one in the pictures above right there under the rear output yoke for the traction bar to connect to, so I should probably just hook onto it with a rear mount for the Atlas.
Your the smart one! Your going to be wheeling very soon! Heck, you've already been wheeling in the TJ.I’m a quitter. You’re not. Keep hustlin.![]()
Thinking about selling everything or calling Marsfab.Beefy updates???!!!![]()
