KOH new "Every Man Challenge"
If you are wnating to run the montero it should be good. definitely beef up the front with the Gen 2 parts and I would do something about the front shock set up. Those 2 bolt fork set up is weak. I have worked the bolts out several time even with loctite it striped the thread on the lower control arm. The factory air locker for the rear is just as good as the arb. i have really enjoyed mine. I would put a hood vent set up to let the heat escape easier. Mine came with 2 tranny coolers. One in the radiator and the 2nd aux cooler in the grill. Reroute your exhaust might help on freeing up some hp. I think it would be a good set up and should hold up well.
cant swap suspension/axles from model to model, yeah i'd run 2.5" king smoothie piggyback resevoir shocks. the "donor" vehicle is LSD rear, so i'd run a ARB in the front, on 33" tires.
Yeah, if you want maximum fun for your money, race ECORS. I wouldn't waste my time driving out there to compete against the jeepspeeders and $50k "stockers" that are sure to dominate the class.
Adam, you run ECORS right? what class? I need to get up with you, and check out your rig. Not seen you since you lived with Kurtis.:driver:
Yep, I'm running in B class. You are welcome to come up to Lexington some time and see what I'm working with. Even better, make the trip down to Spartanburg for the race next weekend!
Hey great video. Even saw some of our ECORS brothers in it!
ECORS
This year ECORS is a 5 race series....Spartanburg will be race number 3. The DPG and Windrock are the lsat two of the year. The Spartanburg race is already qued as the current event on the web site if that makes sense....
