EvilEric
Member
- Jun 15, 2009
- Salisbury, NC
If you are wnating to run the montero it should be good. definitely beef up the front with the Gen 2 parts and I would do something about the front shock set up. Those 2 bolt fork set up is weak. I have worked the bolts out several time even with loctite it striped the thread on the lower control arm. The factory air locker for the rear is just as good as the arb. i have really enjoyed mine. I would put a hood vent set up to let the heat escape easier. Mine came with 2 tranny coolers. One in the radiator and the 2nd aux cooler in the grill. Reroute your exhaust might help on freeing up some hp. I think it would be a good set up and should hold up well.
cant swap suspension/axles from model to model, yeah i'd run 2.5" king smoothie piggyback resevoir shocks. the "donor" vehicle is LSD rear, so i'd run a ARB in the front, on 33" tires.
