I got both axles installed an kind of rolling.
For the rear axle issue i had with the ubolt not fitting over, i did a ubolt eliminator setup on one side and ubolted the other. I do not have the perch welded to the axle, i need to figure out my pinion angles first, but it is under the rig.
Rolled out into the sunlight to compare the wider tires to the original ones and see how far it sits outside of the tub. I am not a huge fan of the rims, but they will have to do for now.
The front axle got pulled out. Bye Bye drum brakes
New axle going in. I had to do the same thing in front as I did in the rear and make a mount with one ubolt and one set to use bolts. Also not welded on, i have to remove the spring perch and take off some material and do the front pinion and caster angle. The steering actually bolts up nicey, but i still have to replace the toyota TRE to the Bronco steering box. It sits in there but it is too small. But i can say it steers now
So had a scare this afternoon. I tried to push the Rover farther into the garage so i can cleanup and it did not want to move. It acted like it was locked up. It did spin for a little bit and made loud clicking sound. I pulled the axle flanges thinking it was a bad birfield, it was still locked. Pulled the tire and it spun, but the other side was locked. Turned it was not a bad axle joint or differential. The wheels i am using, even though they are 16 inch diameter, i have the steering arm contacting the rim. So I need to find a set of 1/2 inch spacer to let me be able to move it around, or maybe a few washers just so i can roll it around until i can get different wheels. Now to sell off the old axle and wheels/tires.
