saf-t scissors said:Ah, I thought this was in that white truck.
That 79 should roll pretty well with some TLC.![]()
BRUISER said:oops sorry it is a '79 460 with 4 barrell carbs...
Ratman said:Smog heads. Find a set of 71 Thunder Jets off a old T bird 429.![]()
StudNuts said:some SCJ heads would be hot![]()
bronc'nBK said:a guy i know has a performance shop that only works on fords. its here near charlotte/huntersville.
RufusTheRam said:are you positive it's the carb? backfiring/diesling at shut off can be timing also...
saf-t scissors said:I dunno that I'd mess with putting DOVE heads on it. You're starting towards a slippery slope where you're going to end up dropping boatloads of cash into that motor before you know what's happening.
Check the timing chain for starters. If it's still got a retarded chain on it, pull that off and put a straight-up chain on. See how you like that.
