The buggy looks super slick and clean.
Despite what Rob says a few pages back the Accord manual transmissions aren't as weak as advertised, with two caveats. First, they are cable shift and don't like to be speed shifted; cable adjustment issues similar to a DSM, and the non-H22 gears aren't hardened on the sides (just like the K-series garbage) so trying to engage a gear under power runs a chance of shearing the teeth off when the synchro hub tries to mate. Second, the tolerances in the gearbox are too tight and like to be loosened, especially the input shaft (#1 reason why bellhousings crack under power). All that being said, I know people who've put 400-500 whp through an Accord box and had it last a decent span, you'll be fine.
You have a few hiccups along the way, however. P0B-A20 is cross referencing to a '96 F22B MT non-VTEC ECU. I have to sit down and verify the wiring but I have a '97 F22B MT VTEC ECU that I may be able to make work, but I am not 100% sure; while the OBD2 Honda ECUs are directly modeled off of the OBD1 units (even use the same sensors) I have never tried to make one play nice without all of the extra emissions gimcrackery. Otherwise, an OBD1 conversion is in order in which case I recommend a Civic/Integra unit as they can be tuned/tweaked as needed, and this allows the annoying EGR stuff to be blocked off.
If you do stay OBD2 it's not difficult to maintain the EGR system on those cars, but they have as bad of a reputation as Ford for acting up. As long as you don't have a Siemens EGR valve then it's a simple 15 minute cleaning job.
why switch to odb1? if you have everything for obd2, why not just flash the computer to get rid of the tranny and emissions stuff?
Hondas were not truly OBD2 compliant until '01-02, depending on the model, in that their ECUs were not reflashable. It's kind of confusing because '99-00 Civic Si ECU were designed to be reflashed, but ended up fitted with an OTP processor.
