- Mar 17, 2005
- N. N. Raleigh, NC
The RV is finally gone so i figured i should post up some pics of the new tow rig...
Its a 1995 C2500 454/4L80e has the 8600# package. 8lug, 14b semi. It has a work/utility body on it. Its got coolers on everything.
Rig shows 346k on the clock I knew when I got it it was a basket case but the price was right. I bought it thinking the engine was junk and the tranny would only get me home..
Engine - actually checks and has good compression, and oil pressure, it appears to have been swaped.
Tranny - been swaped, has non-oem converter (med. bright blue) but its leaking a little the other day when it was cold, i think from the front seal.. It seems to have stopped, but i plan to do some work on the tranny anyway.
Axle - plan to swap in a 14B FF.
Misc - changed wiper motor, need to change the left wiper transmission.
Installed new thermostat, and CTS (coolant temp sensor) truck was running a little rich until it was very warmed up.. Noticed, better running immediately.
I also replaced all the plastic vacuum lines with rubber ones, also making a difference. Thats when i found the vaccume plunger gizmo that controls the high idle was leaking causing the idle to be high at weird times.
Anyway some pics...
Anyway some pics...
