dieselfuelonly
- Feb 9, 2008
- Chapel Hill, NC
fix those ramps. first time you drive up them they'll slide out from under you and you'll be SOL. you need a "hook" type setup on the trailer end of the ramps so they don't slide out.
Seriously though...that's freakin sweet!
The best thing about the jack is you can pull a pin and the foot drops down to the ground, or close enough to it. Then you slide the pin back in the nearest hole, and then you use the handle to raise it up as much as necessary. Much faster than sitting there and cranking for 20 minutes before the foot even touches the ground.
