Ridgerunner
- Mar 21, 2005
- Fuquay Varina, NC
HELP ! no fuel output from IP ???
1996 3500 12v
I drove my truck to the store it ran fine no Issues. I get back in it to go back to work and it would not fire. to day I replaced the Lift pump thinking that it was the problem. I had seen diesel fuel leaking from the hand pump plunger before so that made me think that was the issue.
After the new Lift pump was installed it would still not fire. I then cracked open one of the injection lines from the top of the IP and cranked and I got nothing not even a drop. it was acting like it was turned off.
now I do not really know how this is suppose to work but the plunger that is behind the IP I think what shuts the fuel off. whether the key is on or off it does not move. when the key is on I can pull it up and it will lock in the up position but will still not start or pump any fuel at all.
Does any one have any Suggestions. I am really hoping that the IP did take a dump.
Thanks
Carl
__________________
1996 3500 12v
Thanks
Carl
__________________
