Hey guys. SO this is my first build thread on NC4x4. I had this build on Pirate4x4 but I thought I'd share with the local guys since I see a lot of similar builds going on in this forum.
Background: I've had my jeep since 2003 and have made quite a few changes since then. It was bone stock. The early pictures below show my jeep with 5" bds SUA springs, 1.25" life shackles, 1" body lift. It also had 4.88 yukons with a stock dana 30 and exploder 8.8 rear. 15x8" american racing baja wheels with 37x12.50 irok radials. This is a weekend wheeler and is driven occasionally so I need it to be street drivable.
For the Build: I will be replacing the wheels with m/t classic IIs in 15x10 with 5 on 5.5" bolt pattern.
The build consists of a HP44 front axle from a '74 F-100 with shortened housing (narrowed longside axle tube by 3"), yukon grizzly locker, high steer and complete rebuild with ford inner shafts and chevy outers. i'll be using '75 chevy flattop knuckles with parts mike high steer arms, same model chevy spindles, '84 k10 chevy calipers, '84 chevy caliper brackets and '85 ford hub, rotors and wheel bearings.
Steering:
Parts Mike High Steer arms using NAPA premo chevy 1ton tie rod ends and custom width DOM tubing for the steering links from ECGS.
The back is the 8.8 I was already running but i will be going SOA and adding a 1.25" wheel spacer/adapter to convert to 5 on 5.5" bolt pattern so the wider front axle will match the rear more closely.
The springs are BDS 2" springs SOA w/ no lift daystar greasable shackles. The spring were taller than i wanted but i wanted to run BDS springs. I've have good service out of their products and since I'm not running an antiwrap bar, I needed the heavier duty springs.
i'll be doing 95% of the work myself at a family members shop (Carpenter's Auto). All of the welding is done by Charles Carpenter from Carpenter's Auto in Charlotte, NC. I pasted their website below. They are great people to work with and have tons of experience. Not to mention Charles has been TIG and MIG welding since before I was born.
http://www.carpentersautoservice.com/
This build is now complete but I will try to post pics and descriptions in order of how they happened. if you have questions or comments feel free to post up or PM me.
let the pictures begin...
Steering:
