- Mar 11, 2005
- Sanford, NC
82" between the fenders, I believe they had mind done in 4-5 weeks, but I don't remember. Rich and I did have to go through the wiring and redo all the grounds.
also, how wide is yours between the fenders?
QUOTE]
Looks good, know what it weighs and what you going to pull it with? Got plans for WD hitch?
Question for you?
Where are the three center lights that show its a wide trailer and I'm going to look into it but, if I remember the brake/turn must be placed within one foot from the edge of the trailer.
That is what I remember from the DOT sheets and inspection when I was building trailers. I will see what I can find.
Rich,Dude.. if companies will still sell a new 7k GVW trailer with brakes on only one axle and a breakaway box as an option, you really think they give a shit about the 3 center lights?
Seems like many builders build to be DOT compliant when the customer requests it, or it's convenient enough...
Talked to a few guys last week at a N-SSA Shoot that they want to up grade the springs in the rear to f 350's if they can and they are only towing campers. Was told "they make them ride like a car and tow like shit." Point is way to soft for much weight and the hitch on most is a 10k hitch but I could be wrong, and I know they make the Titan class 5 aftermarket but not sure if for them.You're right though, that is alot for a vehicle like that.. Funny how people wouldn't think towing it with a F-250 regular cab (the shortest wheelbase model they offer) would be a good idea, but the excursion isn't as good a tow rig as the 250 (but not by much)..
Oh well. Hopefully it'll work out.
Richard,I bet that trailer is under 4000lb. My goose (just like Rob's) weighs 3600 without the winch. His bumper pull has a little more steel in a few areas (tongue extension at spring hangers and drive-over fenders), but it has no gooseneck (500lb?). I'm interested to see, because I was sure the scales were wrong when I weighed my goose at only 3600.
My goose basically looks like that in the rear, but it has the 3 center lights. My brake/turn lights are in towards the center like that, so I'd like to know what the DOT says about it. I don't know a way around it with the ramps like they are, except to mount the lights sticking out the corners of the trailer, which I don't want to do.
Richard,
I had mine scaled and it was between 2500-2800 if I remember.
Going to look for the paper. There is a lot of steel in these trailers and most people don't on hook to get total trailer weight.
I was thinking that or a truck stop so you can get the weight of rigs truck trailer and all some may hit 20k + and that may be a little much for a setup like that. be cool to get pin, ball, axle and all.....I would agree most do not unhook and weight the trailer..
I while back yager had his brothers race car scales so I took advantage of that and had mine weighted.. I was very happy.. at that time it was 1976lbs.. i have since added the winch up front so I am sure it is over 2000lbs now..
but if you are gonna do a scale day and weight these things I would recommend finding someone with these type scales.. we put a scale under each tire and one under tongue to get weight..
YOU know how many people I sent down there and never got anything even called and they said thats correct I remember we will get it out and they never do........will do, i'll take care of ya.
Mine took a little longer then they said to but it was done and done very good and they even did some extra stuff for free.i'll post back with how it all works out. if it's not ready in two weeks, i'll be asking for my deposit back and going elsewhere.
mike, i can assume you probably haven't gotten your gift yet...?
