Ridgerunner
- Mar 21, 2005
- Fuquay Varina, NC
I have aways set my pinion angles to be parellel to the out put shaft on the trans. That was with a mild lift. but now with the Cherokee my drive angle is a lot higher. So I was thinking about running a double cardon joint at the output of the t-case and point the pinion up towards the output yoke of the t-case.
Is there any problem with this?
