paradisePWoffrd
Recovering Project Junkie
- Nov 5, 2005
- Newton, NC
The NSG370 6 speeds are a little beefier. I'd trust one of those behind an LS.
Says the guy with a NV3500 behind one.
Headed your way later this week buddy. Rebuilt ARBs, 4.11s, compressor, stickers and a t shirt. Enjoy!
Another update.... after removing all the slave cylinder brackets I was able to get to motor to install perfectly. However the clutch fork still hits the trans tunnel. Outside of that everything fits amazingly well, transfer case looks great with good clearance, lots of room around the engine, shifter comes up in the trans hole very well. I was planning on "massaging" the trans tunnel with a BFH but Novak came back with a better solution. They suggested using a camaro/corvette style internal hydraulic throw-out bearing. They provided me all the part numbers I need to make the swap thus eliminating all my clearance issues. They are also going to make me a custom trans mount at no charge. The guys a Novak have been very helpful and committed to finding a solution to my issues.
Im hoping you are going to list out all the part numbers/sources that you are using, so that one of us might be able to replicate it in the future?
This thing should definitely be a heartbreaker out on the streets![]()
