Random pic thread.
Welcome Monday morning. Georgia Port Authority employee made a small mistake....
I knew I could do it with a chainsaw. I wasn't sure if I could do it with the excavator because the tree was weighted hard to the left. Pushed up the hill hard and let off at just the right moment. Treetop was on fire within 30 seconds :D
View attachment 324926 View attachment 324927
You allergic to poison? Ive got a big pine down that needs the same fate... but the hairy vine leaps out and get me if i look at it too long.
I am, but I'm trying to build immunity, haha.
Haha well, i am open to helping you get more Honey-badger-esq. I spent about an hr hacking at it, and realized it was going to win the battle. Plus its next to a brush pile that is long overdue.
So dude gave me this yard vac for free. Cleaned the carb and runs like a champ. Only thing is the hook up is weird. I’m thinking a 16” long piece of 2x2 angle iron across the back of the mower “frame” with 2 1/2” bolts vertical in it for the “hitch frame” to set on. Drill the bolts to put cotter pins through and let it ride??
That's the standard hookup for a zero-turn, with a 2-point mount so it swings with the zero turn frame. That's also why there are castors instead of wheels and an axle (zero turn makes it move laterally).
It'll work fine with the tractor, just drill a hole for the single pin.
Trying to get some stuff down onnthe property and got a good deal on this 26 gal spot sprayer. Needed a broadcast boom to do the large areas. So for $17 I whipped one up.
Sent from my SM-N960U using Tapatalk
That or just make an A frame style hitch. [btw, clean up that Nasty deck] :lol:
Level EXPERT ...........It could of been MASTER if your hoe hose sprung a leak and shot hydraulic oil on the fire as the tree fell in the fire :smokin:
Ahhh hot apple cider. Yummmmmm
Fixing up this 2001 XJ for a buddy, they've owned it for several years but it's been sitting for a little over a year with a blown head gasket and some other issues.
Swapped in a lower mileage engine and did a 2wd to 4x4 conversion with parts from a wrecked 99 XJ. Few more things to finish up on it and it will be done.
Yeah, I need to pull it out and power wash everything. This winter it needs to get painted. It was a free mower and I have used the shit out of it but I do keep it lubed and parts up to snuff.
I've got the belt covers for mine, but after seeing how much shit accumulates under them, I took them off! Every time I cut grass, I take my air hose & blow everything clean, including the air filter.
