Random pic thread.
Does the water not run all under your porch and seep into your crawl with that grade?
No, its probably a bit deceptive. Its flat in front of the house and breaks to either side. Also the compacted dirt under the porch has about 8-10" of slope away from the foundation. Also the basement walls are waterproofed and have a membrane and drain system. Also there's a ~3ft wide zone of washed stone backfill around the entire basement, 6-12" below the surface of the dirt.
That center plate weighs 300 pounds.
They cover these guys. Pistons charged at 1000psi of nitrogen. We ended up building 12 of them. What you cannot see is the dies behind the bed. We had to remove one to do the work. They average 7 to 9 thousand each....I've pounded some beers I may be off a bit.......damn heavy any how!
18 hr shift. I'm tard.
