Random pic thread.
And ticketmaster
yup, or other things...
inflation calculator says that is 22.89 is Dec '22 doll hairs.
Imagine seeing something like the Nuge for $23 bucks today.
Will it be an explosion or electrocution today?
Place your bets.
Welp neither. I lived and it's finished and pressure checked.
@CasterTroy I didn't blow this one up with the air test this time.
@redneckjeep87 Well let's see. A bolt that holds the tandem pumps to the coupler housing sheared off (and stripped out). That caused the entire pump mount to crack and break in several places. One of the bolts that holds the front pump to the back pump broke out of its hole (only 1/4" engagement from the factory) causing a leak between the tandem pumps. So its tap a the coupler housing, weld up all the broken pump mount brackets, chase the threads on the back pump, use longer bolts to hold the front pump to the back, new o-rings on tandem pumps and aux pump. Put this turd back together and hope it doesn't fall apart again or spring another leak.
