Tom@Hilltop_Machine
- Mar 31, 2005
- Rural Retreat, VA
The ones on my 06 super duty looked the same way.Pretty common for what I understand.Think I got my monies worth out of that brake caliper! I'd say she got a little hot!
(Caliper off the front of my Excursion)
He'll I've seen many cars w/o plates about every week!Couple years ago they made it that expired tag could not be a primary reason for stop, and was even more slack over lock down when you couldn’t get anything renewed in any reasonable time frame. Any of our company vans were several months over due the last couple years….
You won't be able to see it in the rain at night though
We had an old mack that had that in it we used on a dirt haul one time.If you get off shifting gears youd be in love.
You should run a set of triples! But I agree twins is a hoot and an inexperienced passenger will look at you like you just solved the equation to women!!We had an old mack that had that in it we used on a dirt haul one time.If you get off shifting gears youd be in love.
Tri-plex I think they call em?? I have saw one but never used one.I assume one of those levers would be for an aux overdrive,like a brownie box???You should run a set of triples! But I agree twins is a hoot and an inexperienced passenger will look at you like you just solved the equation to women!!
My 1967 Mack wrecker has twin stick 18 speed it is fun to shift. I can haul a loaded 800 Mack down pine mt. without touching the brakes 7 miles across the mountain. It has a gear for every occasion. It has 4 speeds in reverse.Tri-plex I think they call em?? I have saw one but never used one.I assume one of those levers would be for an aux overdrive,like a brownie box???
So, no one from Ohio in a Prius stuck yet?
Some dude brought one of those to deals gap a few years ago and hurt some feelings. Apparently they handle the curves rather wellIt's like a slingshot... only worse
