RobMcBee
Slow n easy when you're not gettin greasy....
- Jan 12, 2009
- Fort Mill / Indian Land SC
wow.... great, now my 1.5" bit has an inferiority complex....
Mine gets mad when I refer to it as "the tailstock of the Monarch"Going in the tail stock of the Monarch when I need a big hole.
Is that like going to brown town?Going in the tail stock of the Monarch when I need a big hole.
225 slant six, all cleaned up and ready for its new home... New rear main, front main, oil pan & valve cover gaskets/seals.. Well except the changing and painting the valve cover.. shhh it's not Chrysler blue, it's old Ford blue.. shade brighter.. advance doesn't sell Chrysler blue.
70s Model Pea Green Valiant, with AC! That'll spin tires [in wet grass]!
Close. 69 dart, factory air, power steering too. Motor is stock.. motor came from another 69 with severe rot near the k frame mount. Took the time to give it that little extra touch of love and maybe I'll be able to get more into resto work (I'll leave body work to my body guy)70s Model Pea Green Valiant, with AC! That'll spin tires [in wet grass]!![]()
Had to pull triples yesterday with the dodge.....
Yep to lazy to walk down and get them![]()
Prorock60? Whos outers? Look kinda like trailgear or spidertrax.
I was thinking Dynatrac because of the funky diff cover.Prorock60? Whos outers? Look kinda like trailgear or spidertrax.
Is it custom width/offset?
Is ecgs having someone cast a diff or likely same casting as something else?Ecgs ultimate dana 60.
Driver drop, but built to Chevy width to use Chevy axles. I'm not sure what brand inner c's. I didn't spec it. It was built for someone else, that change direction. It's perfect for what we need.
I'll ask what brand c's.
It's takes a HP gear that's rotated up. It's slick. Gets pinion offset away from oilpan, but leaves enough tube to get a lower link mount on short side. Going to use all reg Chevy/dodge outer stuff on it.
