Random pic thread.
Not sure how well you can see them, but my outside water spigot was being gaurded by about 10 yellow jackets and probably a few thousand more in the nest below it. Sneaky bullshit level 6.5/10.
Hey now, I'm just trying to fill my birdbath here.
back a shop fan up to the spigot and turn it on high, problem solved and the shower of bee bodies will fertilize the grass.
could you could bend or straighten the tie rod to fix it, but if it's not ripping grass in turns roll on :driver:
It is straight.. some teenager ran it into a tree some years ago and it's been like that, even after straightening the tie rod.. it's not tearing up in turns, so it will roll.. I suppose I could cut the rod and make it grow..
A little hot in the attic today, fixing this mess
Do you have a thermostatic controlled ventilation fan? If not, Id add one in, cuts down on heat transfer from attic.
New sand filter and pump my grandfather gave us for the pool. Way oversized, but by golly its clean! (And yes, I figured out a way to actually hook it up, just wanted to test it.)
Sent from my SM-G930T using Tapatalk
Ran across these two heading S. on I-81 VA., Sunday. Let's see if you can identify the make? Lordy, the cars we forget, & many of you never heard of!
off road and in the creek (again) in the mini-van.
My brother, his wife, son and I were down there Saturday night.
Crazy to think I have seen that river crossing around 5 feet deep, enough to wash a 4x4 ranger down the river and have to be winched out.....
5 million pound press in both compression and tension at the Bureau of Reclamation in Denver, CO. When they did the initial test on it it took something like 4.8 million pounds of force to break. The legend holds with pretty reasonable certainty that when it broke the energy wave blew the windows out up near the ceiling. When they run test they will call the Geological Survey to tell them that if they pick up an anomaly at such and such a time that it was just a test. Pretty neat stuff!
20180417_160616.jpg 20180417_160632.jpg 20180417_160808.jpg 20180417_161145.jpg
Small world. I was their for a few hours Saturday afternoon.
View attachment 272217 View attachment 272218 View attachment 272220 View attachment 272221
What do they test on that?
In the last picture is a steel rod and welded plate that they tested in tension. They also test concrete cylinders in compression. The whole facility is really neat. They have about a third to half that is structural research and the rest is hydraulic modeling. They have a working models of rivers, dams, cavitation test chamber, concrete mixes, a fog room for curing concrete, etc. I could spend a month in there just watching and playing.
