Chris_Keziah
Joe Dirt @ Rev Limit Fab
- Dec 1, 2010
- Winston-Salem
FIFY
You left out the part where you set it on fire
FIFY
Yes, we've refrained from mentioning the implied outcome for some time now to try and throw off the NSA/FBI/alphabet soup agencies reading the open forums for plausible deniability should something happen publiclyI'm pretty sure that's just an implied action with him.
Technically I threw an extra "it" in there to signify starting it upYou left out the part where you set it on fire
I’d spray some gasoline on it and wait a bit before you get it started, that way you can see what you’re working in much better.
I bought a wand that attaches to a propane tank. Sounds like a jet engine when lit. And the looks from neighbors is priceless. But nothing eliminates the weeds that grow in the cracks of the concrete curb and asphalt road like that wand. Makes you want to set the world on fire
Link? I have sudden need for this.I bought a wand that attaches to a propane tank. Sounds like a jet engine when lit. And the looks from neighbors is priceless. But nothing eliminates the weeds that grow in the cracks of the concrete curb and asphalt road like that wand. Makes you want to set the world on fire
Similar to mine. Hot Max 500G Big Max 500,000 BTU Propane Torch https://www.amazon.com/dp/B00282LP34/ref=cm_sw_r_cp_api_i_Fi4PEbZXZA86ALink? I have sudden need for this.
Dogs in the yard/no chemicalsSo aside from the absolute fun factor, which is definitely valuable, whats the advantage of this vs weed killer, which (supposedly) prevents anything else from coming back too?
You just need a little Pramitol down that crack. Nothing will grow for a year.I've fought this "crack" which runs all along my front and side of my lot, as I'm on a corner lot.
I've used:
Weedeater (weekly)
Grass Killer (works for 3 weeks)
Gasoline (works the longest but smells bad and neighbors call DENR and all hell breaks loose)
Torch (works for 3 or so weeks)
Torch is the most fun and scares the old farts cruising in golf karts being all nosy
You shoulda rented the excavator BEFORE tearing the building downSo now this weekend I get to break up the concrete floor. It is no where near solid and has root damage. So the place I was going to rent from did not have availability for this weekend. Found another place in Lugoff. CCE apparently out of Waxhaw, NC. I'll be getting a EZ28
Tracked Zero Tail Excavators $250 for the weekend anything over 8 hours gets a second day rental after 12 hours is what I was told. Unfortunately I have to get a trailer too and they don't include that. $75 for the weekend. So comparable prices to the other place at $325 for the first 8 hours anything after that is $250 per day. I'm also renting a jack hammer for $65. Should be an interesting weekend. If I get the floor knocked out on Saturday I will be taking out as many privit as I can on Sunday at the house.....
Why the jeep did just fine..... I'd post a couple video's but I don't know how.You shoulda rented the excavator BEFORE tearing the building down
Sure, but the jeep doesn't load it in the truck and trailer with the push of a leverWhy the jeep did just fine..... I'd post a couple video's but I don't know how.
That is what son's and step son's and friends of sons are for. Only cost me a good lunch and beer at the local wing shack...Sure, but the jeep doesn't load it in the truck and trailer with the push of a lever
They are addicting.Got a lot done today.
Then we went to the house. Didn’t get stared here until 5 or so.
It's 6:45 and there are two stumps I was burning out now out of the ground and 4 privit cluster on the ground. Man I love this thing....
