- Mar 24, 2005
- Stanley, NC
Speaking of power per dollar...
Ohio Ford Dealer Will Sell You a 725-HP Supercharged F-150 for $40,000
Ah, I see you have one of the pre-ban Rams.
I'll just leave this here...
This Mustang-Inspired Ford F-150 Fastback Is Real, and Yes, You Can Buy It
Came here to post that. I see your Google news feed is similar to mine.I'll just leave this here...
Along with a Mustang and the F-150..
From that article:
They are similar in the same way a 350 Chevy is similar to a modern diesel. I mean, other than the block, crank, pistons, heads, fuel injection system, ignition system, turbo, and emissions crap, they are pretty much identical...Then there's serviceability—in a number of ways, the 7.3 is similar to the 6.7-liter Power Stroke, so technicians won't have a totally new engine they'll need to learn.
For those of you impatient like me...fast forward to about 9 minutes for the results. But intake/cam/mild port work put this just below 600hp. I know factory numbers are a bit underwhelming, and I was a hater to begin with, but seems to have a ton of untapped potential. Really curious what real world factory block/rotating assembly can be pushed to.
Ford 7.3L Godzilla Engine Dyno Results, Teardown & Comparison to Coyote & 351 Windsor "Part 1 of 2"
Folks are figuring out that diesels aren't cost efficient for most fleets. Gas motors now last just as long, cost thousands less up front, cost FAR cheaper to maintain/repair throughout their lives, and have the added bonus of not having to live with a stanking arse diesel for several hundred thousand miles. Any advantages a diesel used to have are pretty much gone.Up here, the power company switched from buying diesels to buying gas trucks, because the trucks were rusting away while the diesel powertrain was still good. A 500,000 mile engine does no one any good in a truck that has rusted away by 200,000 miles.
Yes, diesels are pretty much useless. Especially for towing. The extra load just wears them out faster.Folks are figuring out that diesels aren't cost efficient for most fleets. Gas motors now last just as long, cost thousands less up front, cost FAR cheaper to maintain/repair throughout their lives, and have the added bonus of not having to live with a stanking arse diesel for several hundred thousand miles. Any advantages a diesel used to have are pretty much gone.
Soon there will be F150 EcoBoost's towing all trailers on the way to Harlan
Hate to say it but a 2019 F150 eco boost has 700 lbs higher towing capacity than a F250 V10.Soon there will be F150 EcoBoost's towing all trailers on the way to Harlan
Yeah and the new 1 tons have almost the same capacity as a class 8 truck if you believe the manufacturer.Hate to say it but a 2019 F150 eco boost has 700 lbs higher towing capacity than a F250 V10.
Its was more of a stab at the comical numbers they put on trucks these days. I just don't think a 1ton truck should be rolling down the road at over 18 tons.The implications of that comment only work if you believe manufacturers were ‘telling the truth’ in previous years. Meaning, the EB 150’s capabilities are a lie, but the V10 250’s are accurate.
Ain't no way I'd put 13k behind a F150, but I would try it with my V10.
A “car guy” tried to convince me to buy a F150 EB over a F250 for half an hour because they can “tow the same weight.” I guess he doesn’t understand the concept of GVWR
A “car guy” tried to convince me to buy a F150 EB over a F250 for half an hour because they can “tow the same weight.” I guess he doesn’t understand GCVWR Sent from my iPhone using Tapatalk
