so larry, you are saying to not waste my time with the auto? the main reason i was leaning the way of the auto is so the wife can assist in driving sometimes, and because i never tow much weight.
FYI...you can't do the fuel plate swap in a '92 (as far as I understand it)...
you can do the Governor Spring upgrade (<$20) that will be a major change...
you can also do a fuel pin (instead of the fuel plate)...but it's only worth about 20HP...
as far as cost...it all depends what you want...
I'll tell you I towed my TJ to Crozet (up Fancy Gap) and held 70-75MPH the whole way...uphill...and the truck was completely stock...
what I actually paid for:
1. HTT Stage III - ($200)
2. used 12cm wg exhaust housing ($50)
3. 4" downpipe ($180)
4. gauges (EGT and boost) plus gauge pod...price varies based on brand...
5. BHAF (Big Honkin' Air Filter) can't remember exactly...maybe $25?
6. 3200 spring ($20)
I also bought an Old Smokey Fuel Pin...but it makes no difference in tow mode (with my new tow/play setup)
If I were you, and you decide to go with the auto, I'd adjust the throttle linkage, do the BHAF and 3200 spring and be done with it...at least to start...so, less than $50 and you'll have a very strong tow rig...
Greg
