6BangBronk
- Jul 15, 2005
- Durham
I've been talking to a surveyor and zoning about subdividing off a lot to allow for the upstairs of a 1,200 sf shop to become a dwelling. This is for a piece of property I'm looking at. It has 3 buildings but the zoning only allows for 2 dwellings per property. But in order to do so, it boils down to slicing off some of one of the buildings at about a 20 degree angle. If the building was sliced straight the side building setback line (12' from building) that offsets from it would intersect the rear building setback (50' from building) and would be much farther into the other property and would require the initial building to be cut in nearly half in a straight line and not worth the efforts. But if sliced at this angle, I would only need to take like 6 feet off the front and like 13 feet at the rear.
I picture having the surveyor putting me an iron along the projected angle in the front and in the rear of the building. Then planning where the cut will happen inside. Then frame and brace the new structural wall to be the future outside bearing wall and attach to all the ceiling joists and rafters all bound safely together. Then basically pull out the chain saws, sawzalls / heck even axes whatever and cutting til I can see from iron to iron. Actually everything like a foot over to allow for an overhang.
Carpentry is straight forward from there. Sheath the exterior, box in the eave and repair any damaged roofing, insulate and finish the inside. And possibly some electrical involved.
I tried google-ing this several different ways and came up empty.
Just not built yet. I'm still gathering thoughts on that challenge. And yes, you have discovered my life is FULL of challenges.
Keeps it interesting!
If only he'd moved the apartment back a tad, the restaraunt septic over or anything but it is what it is...
