Small update -
I bought some parts off a guy on craigslist. He was parting out a 2000 cavi. with a 5 speed. So I was able to fill in the missing parts I needed + a few extras
- I got a 2nd complete transaxle - same f23 Getrag but with a Quad 4 bell housing on it. The rear case half and internals are all the same so ill have parts + option for a DOHC engine if i decide i need more HP. (or can go ECOTEC if needed)
- Flywheel, clutch, T/O - mainly for mix/matching and comparing parts to what I have now. I was able to confirm the 2.4quad does come with a 1/2" larger clutch disk.
- Shifters and cables
- Trans mounts
- Pedals and clutch pedal/master and hoses
- I order some KentMoore tools of egay - F23 rebuild tool kit, damn I like that!! I'd bet 1/2 the kit will be usable for every day press/gear work.. The specific tools would have made tearing down my case a tad easier. And a full rebuild will be cake.
- Also got the required shimming tool kit ($20) the tools with a caliper allows you to calculate proper carrier L/R shimming. Its a bull gear so depth isn't an issue just side to side and overall pre-load..
- Also got a GM instructional DVD on doing a rebuild.. $30, id still like a paper manual but seeing it being done is easier to follow than verbiage and black/white drawings. Seeing how much force is used on the tools or slide hammer at various points helps also.
SO what's next
- I need to some links - (either real or mock up) - to start doing some layout. I've got some rough chassis layout in mind but need but I need to see the links moving to finalize any one design. I'm thinking getting the ends/adapters I need and using some conduit like i've seen others do. Help spread the spending out some also..
- I can start laying out my plastic tube for the mock up of the center area. This will let me start seeing how much space I'll have and visualize other things like pedals, fuel tank, etc..
I'm debating on investigating doing some heat treated thiner wall links vs regular stuff.. Need to weigh the pros/cons etc.. Ideally I could find a local heat treater to work with.
Thats it for now..
