DannyH
smokey burnouts
- Jan 10, 2014
- Stanfield, NC
Twisted rice burning Tin Can Toyotas are cool, but V8s are cooler.
Here’s the base build:
-Miller Motorsports replica base chassis
-Dana 60s front and rear
-Aluminum links
-4.8 LR4 (some sort of power adder)
-TH350
-Atlas
-16” travel Swayaway coilovers on each corner
-114-116” wheel base
I bought the chassis off the board from [mention]BRUISER [/mention]sometime late last year, put it in the shop, built a stand for ride height and slowly began to collect parts. The chassis is a fairly close replica to the Miller Motorsports chassis and I’d love to build a 4800 class car out of it, but my college student/ part-time machinist budget says no way. My next choice was a trail rider and possibly some comp crawling.
Currently, it sits at roughly 18” belly height with the axles 20 inches off of the ground. It will end up a little higher as the plan is to run 42s.
The build began with locating the axles and determining the wheelbase and length of the lower links. The lowers are 2.25” OD 7075 aluminum. I got a smoking deal on the raw Al sized at 3.25”, tossed it in a CNC lathe and let it turn. It took about half a day to hog the inch of material off and tap the ends. I installed the 7/8 heims and set the links under the rig.
Next up was the motor. I bought the 4.8 thinking it was a 5.3. It was cheap and nighttime when I picked it up. I didn’t have a borescope and didn’t really feel like trying to check for flat tops. I went ahead and completely rebuilt the 4.8, new bearings throughout, stage 2 truck cam, ls6 lifters and springs, had the heads machined and valves ground/seated. Fingers crossed it’ll have enough power to turn 42s... I’m hoping I can make the truck intake work but I’m not opposed to a different one.
Edit:
[mention]rcalexander105 [/mention] aided in creation of thread name
-Aluminum links
-TH350
-Atlas
Edit:
