ScottR
It's never done.
- Mar 21, 2005
- Raleigh, NC
Betsy's Engine has gone strong for ~170K miles. It had a blown gasket so I am doing what any Jeep owner would do- time for an upgrade. Turning the 4.0L into a stroker. I am going to make it a 4.6L.
Parts:
4.0L Engine Block- Cylinders bored 0.030. Deck Milled 0.020
4.2L 3.895" stroke crank
4.0L Piston Rods
Keith Black UEM-IC944-030 pistons
CompCams 68-231-4 206/214 degree camshaft
New Timing Chain
High Flow Water Pump
New Oil Pump
Ford 24lb/hr injectors
Newer High Flow Intake
Compression Should be around 9.6
Here is the where the engine use to sit.
Here is the engine block torn down. Taking it to the machine shop tomorrow.
Original Air Intake
Newer 4.0L Intake (runners are much smoother) that I bought from a buddy 4 years ago for $20. I guess now is a good time to install it. Just need to install the new Ford injectors and my throttle body, etc on to it.
Parts:
4.0L Piston Rods
New Timing Chain
New Oil Pump
Original Air Intake
