Hokie_YJ
- Jul 22, 2006
- Johnson City, TN
I've been off work this week so I finally got to work on this thing a little bit for the first time in a month. I've had a lot of other stuff to do so I haven't made as much progress as I'd like though.
I cut and moved the tube that was hitting the right front shock when it was flexed out. The joint is slugged with 1.25" tube.
Then I added some reinforcement to the chassis side track bar mount and made it double shear. Before it was just a bolt threaded into a bung in the chassis.
Most of my time this week has been spent redoing my screw ups though. I had to cut all the drivetrain mounts and angle everything toward the drivers side a little more. Luckily I had only tacked everything. I got in too big of a hurry the first time around and didn't leave enough room for the driveshaft. It's still SUPER tight, but I think it will work now. After I got everything relocated I bent up a skid plate for the engine. I tied it into the motor mounts and used tube flanges to make it removable.
Hopefully I'll be able to get a little more done this weekend.
