Cherokeekid88
- Jun 30, 2007
- High Point, NC
Anyone gone from a traditional style gas water heater to a tank-less style? I am guessing the tank-less + installation is going to be run more $$$, but is it worth it?
I agree with this. The house we bought has a tankless heater and it is annoying waiting for it to turn on when the kitchen sink faucet has to run for close to a minute before anything hot comes out.I had a small (30 gallon tank) and the switch was worth it. If you have a large tank and don't experience hot water shortage, it is hard to justify the costs.
I think after rebates, my install cost $3k. I didn't have a choice because my previous unit was buried under a counter and completely non-serviceable without destroying the counter/cabinets.
your hot water heater needs a circulation pump.I agree with this. The house we bought has a tankless heater and it is annoying waiting for it to turn on when the kitchen sink faucet has to run for close to a minute before anything hot comes out.
Although unlimited hot water once everything is going is pretty kewl
most of the new ones have a circulation pump built into them, just takes a return line and some programing on the unit itself.A timer system and a pump can cure the long wait for hot water at the tap. Ours circulates hot water from 6am to 8pm. Of course, this is also an additional up-charge (previous owners install it in our new house).
I knew this but looked recently, as I am considering buying a new heater. The electrical load required for one not very big was ridiculous.if you dont have gas in your house already. its 100% not worth the cost to run an on demand on electric.
How much is a normal tank replacement cost? around 1k?In our old house, we had a small (30 gallon tank) and the switch was worth it. If you have a large tank and don't experience hot water shortage, it is hard to justify the costs.
Doesn’t that defeat the point of having a tankless system? It would have to run just to keep water in my pipes warm?your hot water heater needs a circulation pump.
The volume in the pipes is tiny compared to a typical water heater tank.Doesn’t that defeat the point of having a tankless system? It would have to run just to keep water in my pipes warm?
It doesn’t run continuously has a high and a low tigger for it to run and circulate. If you insulate all the pipe work as it’s installed they retain heat fairly well.Doesn’t that defeat the point of having a tankless system? It would have to run just to keep water in my pipes warm?
Both.How much is a normal tank replacement cost? around 1k?
Is it the install on the tank-less heaters or the actual cost of the tank-less heater that makes it more expensive?
and then you flush the toilet and have 30 seconds where there' no water pressure and its really hot.Just be like everyone else and turn the shower on and take a poop by the time that’s done you got hot water
Soo how shitty does your water pressure have to be for this to occur?and then you flush the toilet and have 30 seconds where there' no water pressure and its really hot.
Or do like me and say, "Oh I'll flush after the shower to avoid that," then forget, and get yelled at by your wife later for leaving a giant turd.
You can tell here when somebody flushes. Our peak pressure is 50 psi, on a well so it varies. If it happens to be at the bottom of the tank cycle (30?) you can definitely tell the difference.Soo how shitty does your water pressure have to be for this to occur?
I have seen it in the movies but never had it happen in person.
Ya mine doesn’t change temp or pressure. But the water heater i swear is set to 135 degrees if not moreSoo how shitty does your water pressure have to be for this to occur?
You can turn that up.If it happens to be at the bottom of the tank cycle (30?) you can definitely tell the difference.
its a 30/50 switch. I do have it dialed to go a little higher.You can turn that up.
