junkxj
Well poop!!!!!
- Nov 19, 2014
- Mexico!!!!!!
Yes, I know.....
Plenty of these threads in this and other forums for sure....
But to the point. I would like real world knowledge about running 27 spline 4340 axles in a 4 cyl tj with a full case locker. I plan on running 34 inch swampers, nothing bigger as this is a budget/fun build.
Having read several hundred threads, and many articles I am fully aware that this is not ideal, and stuff can and will break.
I bought a "bolt in" 8.8 last summer, but after figuring in the gear change, locker, and drive shaft cost it was well more than I wanted to spend.
At this point I am thinking good shafts, with a 4cyl, and a full case locker will hold up to mild wheeling on the stock axle with not a lot of abuse.
I do have experience wheeling mildly built rigs, with what most people would consider under sized axles. To date I have had nothing but fun with theses rigs. I am in no way too proud to pull the winch cable, when a few tries with progressive throttle doesn't work.
I do understand the 30 spline upgrade is an option, and it is definitely stronger. But the fact of the matter is that the 27 spline stuff is much cheaper, and having researched axle strength I think the 27 spline may be up to the task..
I will respectably ask for no " a dana 35 is junk" , "why Polish a turd" or " bolt in a 8.8 for $500" posts, only real world experience with a low power/ lite weight rig with 4340 shafts.
Thank you very much in advance!
