The list of which 4.0L Jeep motor will fit your Jeep
My dad needs a new motor because of a cracked block. He had the head complete rebuild because this was the original problem but we doesn’t want all the money he put into the head to go to waste. What blocks will fit this head. 2000 XJ 4.0. Please let me know if you need any more information.
2000-2001 Jeep Cherokee XJ 4.0L
00-01 XJ
You can also use 91-01 XJ, 93-98 ZJ, 91-95 YJ, 97-99 TJ engines, but you will need to purchase separate coil pack adapter brackets since the 00-01 is a coil pack motor and earlier engines do not have mounting provisions. It would be cheaper and easier to just find the correct 00-01 motor.
Found a ‘95 4.0 that I’m waiting to hear back more info on. Not sure what it’s originally out of, but someone stuck a T176 behind it.
I’m looking to put a 4.0 in my ‘87 YJ with the 258/a999 in it. Question: will I need to source a flex plate for. 4.0, or will my 258 flex plate work? And starter for that matter.
258 flex plate will.work. They're both balanced the same way. Same bolt pattern too
I'm hoping this thread is still open and/ or read. I want to swap a 97 Wrangler 4.0 motor into a 98 Cherokee 4.0 car. I'm wanting to know how easy and what differences, including harness and computer. Anybody out there?
Came out of a thread in the general chat. Here's the comprehensive list of what motors will fit which Jeeps.
1987-1990 Jeep Cherokee XJ 4.0L
Renix motor - you can use 87-90 4.0L
91-01 XJ, 93-98 ZJ, 91-95 YJ, 97-99 TJ You will need to relocate temp sender to thermostat housing from HO motor. Also need to use all your Renix accessories, distributor, flywheel/flexplate, etc. 00-01 is not recommended due to crappy head. Some people say the 0331 isn't as bad as people say. We scrap Jeeps, more than likely if we get a 0331 head Jeep in the head is cracked, well over half the high mileage 00-01 ones we get in have this problem.
1991-1999 Jeep Cherokee XJ 4.0L
87-90 XJ - Renix motor, lower power output, not recommended
91-01 XJ, 93-98 ZJ, 91-95 YJ, 97-99 TJ (read 87-90 XJ section above about 0331 head issues on 00-01 XJ)
00-01 XJ
93-98 Jeep Grand Cherokee ZJ 4.0L
99-04 Jeep Grand Cherokee WJ 4.0L
99-04 WJ, 00-06 TJ - 2002 and up were TUPY heads and did not have the cracking problems that earlier 0331 heads had. 02+ are recommended.
1991-1995 Jeep Wrangler YJ
1997-1999 Jeep Wrangler TJ/LJ
2000-2006 Jeep Wrangler TJ/LJ
There you have it, please let me know if anything is wrong here. This was all gone off of by memory and experience here in the shop. I think I got it all correct but if anyone finds issue let me know and I'll update it. Also, some motors might have slight wiring differences with the temp gauge wiring because after 96 they stopped putting them in the cylinder head. You can either use a 96+ thermostat housing and extend the wire, or you can drill and tap your existing housing and extend the wires. You can also be brave and drill and tap the head. I'd rather do the housing and extend the wire and not risk it.
There are also some other differences with swapping HO motors into Renix Jeeps and the other way around, most of it is gasket related and easily remedied with using the correct gaskets.
Hope this helps some people!
I'm a new member. I just posted a question. I've read your List for which I thank you and appreciate your research. I'm hoping for more specifics regarding a 97 Wrangler 4.0 into a 98 Cherokee which has a damaged 4.0. Any accessory or computer issues or anything else complicating a bolt-in "plug-and-play"?
Swap all the accessories, including motor mounts, intake, etc, from one to the other.
The long blocks are identical.
Okay so I totaled my 1997 Jeep Wrangler 4.0l and just recently bought a 2002 Jeep Wrangler 4.0l, my plan is to stroke out the 97 4.0l and swap it into my 2002. I know that the 02 motor has coil packs vs the 97 having a distributor..
Can I swap them?
You can, but you'll need to fab a bracket to mount the coil pack. But, if you are rebuilding the engine anyway you might want to look into doing a 4.0L TUPY head. Much stronger and has the bosses for the coil pack mounts.
Isn't there a different coil pack that can be swapped in? I remember reading about the coil rail having issues and people swapping in a different coil pack.
I'll be honest, I'm not sure. It's been like 6 years since I closed the shop and at that point the solution was a bracket.
Can I swap them?
It is nowhere near a direct swap. The accessory drive mounting points and motor mount bosses are totally different. You'll want an up to 99 model TJ engine to replace it with.
Or yes if you throw enough money at it
Sacha Baron Cohen Thumbs Up GIF by Amazon Prime Video
I got a question I need to figure out what is going on with my 1997 Grand Cherokee landlardoo 4.0 v6 transmission and the motor bc the transmission is going out I think bc some days it's will run an change gear an some days it will go an it want go over 20 miles per hour and some days it want go over 40 an some days it want move but it go in reverse and then some days it will just go fower and some days it want move at all so can anyone help me out with what they think it's the problem an then the days it does go then my moter will start smoking an then once I shout the motor off it stop smoking an ever time I go to start it up I would have to jump it off every time an then it got where it will run an as soon I tap on my break it shout off so can anyone please help me an let me know what they think it's the problem or whatever is wrong with it bc I'm to the point to replace the motor and the transmission but I want to do with a v8 but I'm not sure bc of the wair harness
Aw c'mon man. If you can read half the AI bullshit that's on the internet these days, this should be no problem. It's just South Carolina style.
"I got a question:
I need to figure out what is going on with my 1997 Grand Cherokee Laredo 4.0 v6 transmission and motor. The transmission is going out I think. Some days it's will run and change gears, and some days it won't go over 20 miles per hour, and some days it won't go over 40, and some days it won't move but will go in reverse, and then some days it will just go forward, and some days it won't move at all.
Can anyone help me out with what they think the problem is? On the days that it will go, my motor will start smoking and then once I shut the motor off it stops smoking. And every time I go to start it I'd have to jump it off, but then once it was running, as soon I tap on the brake it shut off.
Can anyone please help me an let me know what they think is the problem or whatever is wrong with it? Because I'm to the point to replace the motor and the transmission. But I want to swap it to a v8 but I'm not sure about that because of the wiring harness."
That better?
"I got a question:
That better?
better, but still likely the wrong thread. Maybe a mod could correct that?
