From my research yes, I️ plan to run one with full manual control this way.
If you want it to drive like a stock one you will need the tcu, but I️ know nothing about making the swap work that way.
The trans is controlled fully electronically. It has two solenoids to make it shift, and the combinations of these two solenoids being on-off give you the 4 fwd gears. You still need a cable to change PRND.
The radddesigns/winters shifter combo looks to be the best, and easiest combo to do both. Definitely one of the best shifters for offroad, and he custom fits the micro switches into the unit to control the solenoids.
Not sure on the option to control the lockup converter, but could also do a push button switch for it.
http://www.radesignsproducts.com/tech.htmlhttp://www.radesignsproducts.com/tech.html
