DRaider90
Uwharrie Off-Road Volunteering
- Oct 23, 2007
- Weddington, NC
Since I don't have a front locker option for my truck I have decided to run the route of getting the front welded up. I put some Superwinch (since Aisins are super rare for my truck) hubs on the truck, so on the trails if needed I can unlock one/both hubs for turning etc while leaving it in 4wd. I just have to get the 3rd member dropped from my Silver truck, get it welded up and swapped into my Red one (so I have a backup diff).
BUT, my question is why is there so much debate about welding up the front or the rear? I understand welding (spools and lockers in general for that matter) the spider gears makes it so the tires can't spin at different speeds in turns (tire chirping, accelerated tire wear, lack of turning radius), and it can put a lot more stress on parts.
But I read around and talked to some people and you always get a different opinion. There are the group that says weld up your front and don't mess with welding the back because of the road manners/tire wear. Then there is the group that says weld up the back, and don't mess with the front because you will grenade cvs, hubs, etc.
I guess it boils down to your own experiences etc, but I would expect there would be some more definitive answer on this considering how long welding diffs has been around. So while I have made my decision about the front getting welded, I still debate getting the back welded (it is my DD). So opinions and views into this from anyone?
The only way the carrier becomes unchangable is if you weld the spiders to the carrier. I do mine that way but you don't have to.
