ANDREW W CHESTNUT
Member
- Mar 9, 2018
- Erwin
Well be easy this is my first fabrication adventure and post on here
.converting my 98 ram 2500 from 2wd to 4wd. I took inspiration from blakeape and montanatrout on here only difference mine starting 2wd lol.
Anyway I'm having trouble figuring out how to mount a track bar. I don't want to remove the crossmember as it ties into the engine mounts.
I'm thinking if i could find some sort of rear axle tube mount i could make it work... thoughts?
Also I'm not totally sure on shackle angle...i did my best to compress the springs and mount them to a 90 degree but came out on the soft side...am i ok? Or should i run a boomerang style? Longer?
Any help would be awesome
.converting my 98 ram 2500 from 2wd to 4wd. I took inspiration from blakeape and montanatrout on here only difference mine starting 2wd lol.Anyway I'm having trouble figuring out how to mount a track bar. I don't want to remove the crossmember as it ties into the engine mounts.
