Trailer decking
White oak from a sawmill
What Matt said... I bought rough milled white oak from a local mill for about 1/3 of the cost if I had gone through Lowe's. Then stained it with some trailer deck stain.
Here's how mine turned out with all the details:
I did the same process with my previous trailer when I replaced the deck. This new trailer will eventually get a new deck (came with pressure treated pine). I’m just hitting the tops with used ATF. When I do replace (maybe next year), white oak coated on all sides with the used ATF prior to installation.
Go with sawmill White oak for longevity. Most all pressure treated will be MCA treatment and the base lumber will be similar. Unless you go with a #1 prime dense KDAT
